If i want to get my boards done and ready to go right away next week i should probably order those boxes or try and find some from the local suspects (home depot, lowes, hardware/electric supply). These results appear to be better than the 4.20 FLESC (non-plus) which makes me super stoked to get this set up.
Market E, the dad, wants toys but has to be frugal about the spending. Is the in for the “best bang for the buck” market, doesn’t want the cheapest but doesn’t want to go all out.
I don’t understand everything totally, but the absolute max current setting in the standard fw is 130 or 150A. If you run 100A motor and batt max than you could hit that limit which result in funky strange behavior or cut out. Maybe to try the no limit fw and set the absolute max to 200A?
On v4 hardware I always found I needed to set absolute max current really high to avoid over current faults. I guess its just the limitation of the 2 low side shunt amplifiers on board the drv?
@doomy good to hear your drv is still alive. What do you mean when you say you disabled the OC protection?
Nr. 1 is assembled.
Can I use the programming funktion of the vesc-tool and another vesc as programming tool to get the firmware onto this one or do I need to use an ST-link?
My understanding is that you’re going to need the ST-Link to burn the bootloader, once thats finished you can write the firmware through the Vesc-Tool or whatever other means are needed for 3.5 (or older) firmware.
Thats pretty cool I didnt know that this was even a thing - Because the cheap FOCer is designed to be a 1:1 replacement i cant imagine that it wouldnt work. @shaman would need to chime in here on this.
@Prism give it a shot. I’ve never programmed a VESC with another VESC. If it doesn’t work, the other way I know to flash the bootloader is with an st-link.
