That looks super nice! Certainly wish I could buy something like that cheap.
If some some reason you needed minimum depth maybe the xt30 could be at an angle. Or fully horizontal but that could be too annoying and wouldn’t get tugged out as easily to protect.
Hmm do we need a separate thread for mounting charge ports vs procuring them…
I was going to use some of these fuse holders on my board to keep em easily changeable. They’re nice n mountable right by the charge port for plus easy access.Is there a reason I don’t see glass fuses talked about as much?
The SP13 2-pin connector has been my default for some time now. Handles most charging currents I end up seeing on a board, is low-profile enough to not invite issues, the cap is easy to work with, and the assembly/implementation is straightforward and easy to solder.
Not sure how I missed it! Swear I searched for charging ports, connectors and didn’t see it. Happy to close this topic and merge the info in I still can’t edit wikis, but once I can ill do that.
