So I have a new 12s 4A charger that came with an XLR connection. I’m going to swap it out for a 5.5 x 2.1 barrel connection. What size wire should I use? Can these barrels handle 4A? Just want to play it safe.
If it’s the plastic kind, maybe not, but the metal one can. Got a picture of yours?
These are what I have laying around. I stripped off the existing wires because they were only about .5mm (24awg)
Should be fine @ 4a. I use the same plug on a 4a charger.
I’m dumb; thought you were replacing the charge port on the board; yeah that’ll be fine!
good choice
20AWG or 22AWG, will say on the wire insulation
Yes, most are rated for 5A, a very small number of them are rated for 7A.
Thanks for the input I appreciate it
