Carvons v4 need help fixing
Yeah @hummieee was telling me when u get to that point to bake it in order to soften the epoxy
I would Dremel through
it’s a fuckton of work…
but they’re awesome drives
if you fuck them completely up… they won’t be worth shit
Guess I could
Also @kook I now that these were awesome was looking forward to them a ton
Direct drives are awesome and if I could make them perfect for my setup then even better
Maybe even I could just order new stators and refit them if something goes wrong
I’d caution that… I don’t wanna fukkup the insulation on the stator… I’m going for my dremel now… I just need one good phase or at least one good stator tooth to count the winds…
good chance they’ll just turn into a front truck with no motors to match the Carvon XL I have on the HyperBeast lol
Lol
If you wanna send over a pair though…
just ā€œfor scienceā€ can you put the rotor back onto the stator?
I fabbed a tool to do it… your mileage may vary
Huh
What do you mean put your rotor on the stator?
put the can back on
Why now?
What would that do?
see if you can do it
Oh it sucks it takes months to centre it and finally get it onto the screw holes at the back
I hate doing it
these were notoriously a PITA to assemble as described by the people assembling them 2ish years ago, disassembly and reassembly was highly cautioned against
don’t put the screws back in… just slide the motor bell, rotor, can whatever you call it over the axle and see it you can get it mounted back on the stator…
Yeah it is aweful
This morning took me like 10 min to get into place
@kook why is that
What do you want me to test?
no need to again if you’ve already done it… it is a pain in the ass… that is precisely why I made a rotor centering adapter…
@kook what size gear puller is necessary 6inch?
found a local shop which does 6inch and 4inch ones
so managed to get stator 1 off and gonna try starting to unravel today
i have removed the black and grey piece and have isolated all phases
gonna count the amount of strands within the phase and then try unraveling all phases
thanks to everyone picks to come
Here is the stator
Not sure what the next step is
Not sure how to unravel The phases
Do I go from the end or the start
@kook @hummieee @Scepterr
