Can vesc 6.6 plus run 13s?
Hey guys just wondering if anyone has run 13s on a vesc 6.6 plus without any issue
Flipsky?
Regardless of what esc if you’re doing regen it’s worth staying further from high voltage as when braking you have a voltage spike.
I’mma go with a hard no
13s Liion is unsafe on most “60v” escs, especially with flipsky
So play safe it’s a hard no uh . But has anyone had any success running 13s ?
@jack.luis has run 13s on a xenith (or unity, not sure) without issues but its a risk you probably shouldn’t take
Unless u want more speed, and you’ll actually use it, will likely be less efficient. Maybe run the field weakening software if u want more speed
I wanna try this so badly with my high gear ratio setup on a stormcore, but i might want a better health insurance plan first
I heard it was pretty safe. The few people I’ve read who were using seemed to be happy with it.
I have a perfect space to test it. I’ll have some of my friends accompany to make sure I’m okay and I’ll be fully geared up.
off to derail jail i go
I’m too old and already injured for that. Maybe will put it on my soon-to-be bike…if 40mph doesn’t satisfy.
Bunch of people were running 13S on OG focbox.
I know Deckoz was, maybe @Dareno too?
Isn’t it just a matter of not going over a certain erpm?
Not on v6 I believe. On v4 the eRPM limit was 60k, which presented problems when using high KV motors in 12S. v6 has a 150k limit, which is very difficult to reach with what we use.
Why do it? I feel like u can get the torque you want with two vescs easily at 12s, and maybe even worse efficiency at 13s, and then maybe blow up and land on face.
I get bike flipping torque with one Vesc and a hub motor on 50v
I don’t know, I am building a 12s right now before that I was on 10s for the longest time.
I’d do it if I had the room in the enclosure just for science.
I use 13s on focbox for ages, question has to be is a flipshit 6.6 as good as OG focbox.
And I found 13s totally unnecessary BUT really really fun lol
And @DEEIF
I run it on a Non-Blood unity perfectly fine
What’s a non-blood unity?
Can confirm. I set my hummies up on 13s on ESCapes and I feel i would have been disappointed on 12s.
OP, FWIW the only flipsky 6.6 i ever used lasted 3.2km on 10s and blew up.
