I’ve just stopped using mine altogether. I look else where for esk8 parts now and try to stay away from anything evolve.
These look promising for a evolve rim swap
They do. A 47t gear is what I use now. Not really into stretching the tires though and they don’t have the drive gear bearing?
Maybe you can find some bergs with @moon @longhairedboy 47t pulleys
But I don’t know if you will have enough axle length it could be a trial and error thing so it might not be worth the money
You can’t use standard tires with bergs though, right?
Why is this hub thing such a mess? Can’t they just make a good normal hub for 6" lol
Yes they only fit 6x2 clevers or if you can find the OG haggy tires
What about Metroboards hubs?
Swap the bearing for 8mm will they fit an evolve/vereal setup?
Good question @jack.luis is the metro guy but if they fit on their Dkps they should probably fit on evolves DKps
InfinityHubs are the best I’ve used so far. they have all the mounting options, easy tire/tube swaps and with some rim tape I’ve had no issues with blowouts.
Yes but they are all sold with 10mm bearings not 8mm
I mean if you can swap them even with a press that’s not a big issue
jesus that’s the price for one hub?
4
Price for a set of 4, who TF buys/sells hubs individually?
Too bad they’re out of stock
Okay I found these but I’m worried about the gearing ratio and changing it some how, maybe on the motor side? maybe some drive is cross compatible.
Have a look our m1 rims, we have CNC pulley made for evolve DKP
