CAD Ideas and Inspiration (Serious)
Golden gear ratios are really hard because the motor RPM is a range factor of 3 and the target speed output is a range factor of 3 so gear has to pick up that range factor of 9
I mean we can all say we want a 1:4 ratio for everything and pick the motor kv and battery voltage accordingly but even then you’d need every kv from 90 to 270 for people to be happy
I think there are “golden ratios” for a given kv motor.
Personally I think the sweet spot is somewhere around 3.5/1 for 170/190kv. If you go any lower for example 2.5/1 you lose torque big time. If you go any higher than 4/1 you have almost no top end.
Agreed, I think if a vendor sold this planetary drive set up, you would see 2 or 3 pre-set motor kv ratios to choose between for urethane, street carver, or mtb.
But will we see it in 2020? :thinking:
Fully possible:
The ultimate solution is a DD for eMTB :wink:
Would it be possible to make a gearbox for emtb with a clutch to switch gears between 2 different ratios?
That would be really dope.
Yes, but how many pesos do you have to fund it?
everything costs! actually a CVT clutch may end up meeting your wishes and expectations… readily obtainable, cheep,l been proven
Do they make them small enough to fit a skateboard truck with 8-9” wheels?
I’d definitely take part in the first batch preorder. But as far as funding stuff I am not really rich even in pesos.
I have one on my 5hp two-smoke engine that powers my fat-bike… so yeah… and with a little search… i’d say yeah… and if not now… infinely/possible/build-able/likely
I will look it up
I mean if you’re feeling kinda risky, you can pull the clutch and gearbox assembly from a drill. If you’ve got a 4045 motor or something small like that it’ll probably run… just get a servo and Arduino with accelerometer to switch it once you reach say 15mph
gears and such are esoteric and fun… and I may be wrong… but a CVT clutch/transmission is relatively cheap and proven
Heh?
I toad ya
So if anyone wants to PayPal me $100 so I can do some science…:wink:
I need to watch an “how this stuff work” video to understand how this stuff work.
@ZachTetra we’re just the big-brained guys… let our minions make it work…
hey minions
quit working on out of date gear drives and make us a small package/easily tunable/cheep/ CVT transmission for our esk8’s
Bro I don’t know if that approach will work, you need to praise them.
