Im currently leaning towards the gear drive as i think it will be easier to package into a workable drive. maybe something like this with metal gears and a huge bearing so that wheels can be hot swapped.
im thinking that the left most truck will dip the COG most when in a corner which may cause stability issues. maybe right would give the most stable right?
I like your thinking but im trying to keep it as “low profile” as i can. Im not a big fan of top mount battery box’s but it seems to be the only way to get good range without sacrificing ground clearance.
I believe the further the pivot point from the hanger, the more turning capability you will have. Definitely will depend on the dampening system but I see the right as being a super carvy mtb and the left being a racing mtb setup.
What makes you say this? My guess would be that the longer mount on the left would make the deck move around more and so make it less stable at speed, but better for carve. With the right being more stable. But this is just a guess and i have no data to back this up.
my guess would be that shifting the pivot does make a difference. lowering the pivot means that the COG is higher relative to the pivot, making it inherantley less stable, in an extreme case if you could raise the pivot to above the board COG it should self centre without any bushings.
What I meant by the keep the same is that, if you changed the kingpin distance you wouldn’t change anything else about the trucks. Not really possible unless you make two trucks or it can be adjusted.
I think that idea about cog and center of rotation might be running into the pendulum fallacy. Not sure though.
Working on a custom motor with some friends…
It’s not strictly for esk8 but I’m trying to steer it towards having the flexibility to be adapted to our sinister purposes…
So if anyone’s down for a switchable 44/75kv motor that’s 80a-capable… Keep one ear open
Disclaimer - we’re still very much in R&D so don’t expect anything tangible for a while lol.
This box is similar to what I have in mind, nice to see that it doesn’t look that bulky
How accurate is the deck and trucks drawings? And could you share them? My trucks are on the way but if I would love to start designing the mounts early
