Hello,
I just received my new ESC (the @Esk8supply one) and when I took off the sensor plugs from the old ESC, some wires just broke.
I went to my local electronic shop but he told me there’s no way he can find those.
I can order them but I’ve been waiting for weeks now.
So the question is: Do I need the sensors to run my Esk8?
your best bet is to probably make a post in the parts wanted section asking if someone in the EU has any on hand. that will most likely be the cheapest route.
You don’t need sensor wires. Sensors are only needed at exactly 0.0km/h so the controller knows the rotor position, to know which winding to fire up first, basically.
The worst-case scenario with no sensors is that you can “hip-flick” or kick push just to get rolling (even if super, super slowly) and then the motors work fine. The best-case scenario using finely-tuned HFI is not any different than using sensors.
That being said, tuning HFI has been something that doesn’t seem super straightforward and some motors just don’t seem to like it very much. I’ve been struggling with it sometimes, and other times it just works super-awesome. We’re still in the process of learning, as HFI is relatively new.
