I’m interested in a set of the 184s. Using the appropriate length shoulder bolt should yield a similar axle length to an E caliber yea?
My belt snapped because I was using super small wheels and rocks could get pinched between the road and the belt on the pulley. Then the little tear grew and snapped. Another thing that enclosed belt drives would solve!
I also like belt drives for the ease of switching setups, when you are first starting to ride and figuring out what you want.
Not for us European folk they ain’t!
Do I really need to put *in USA to get my point across.
I don’t want to troll, but this only (special-ordered) set of Boardnamics 184mm in existence is the motherfucking bee’s knees
These would be an excellent stocked item. These make Caliber E look like plastic Wal*Mart trucks.
Showoff
Boardnamics shit is the shit!! besides being priced really well is solid. Been Running my 4wd setup for a while now without a single issue
Not trying to show off. I just think these should be more common because they are very good.
I’d scoop up a pair for the kicktail if they were available
I wish I bought the other set lol
Here is my final design for the new idler, 2020 EDITION (or late 2019 I guess!)
This new idler is better in every way from my first version.
- It can go behind the wheel. No more clearance issues!
- Uses 1 tool instead of 2 to adjust
- 24mm diameter vs the old 22mm diameter. A bigger bending radius for the belt is good. Small idlers will destroy the fiberglass cords (won’t name any names
) - It’s lighter, if that matters
You can still adjust how far it sits with a few M6 washers.
Hmm nice screw retaining slot.
*mouth starts frothing
What’s the length of the shoulder bolt when tightened? Also @Boardnamics when will these be available?
about 44.5mm x 8mm⌀
Sweet, so like an E Caliber. I’m gonna get a set then when it’s out.
Not if I buy em all first!
My number 1 fan!
I threw in a small quantity of 184mm on my last order. All my new stuff is in production
Will the 184s come with 40/50 split baseplates? Or just naked hangers?
Put my name in for a set
