I have always wanted a pair of these and now I am able to provide them to the masses
Here is what I am excited to introduce:
The BN220 is a precision hanger designed to be a drop-in replacement for Caliber II trucks. They’re wider, machined from 1 piece of aluminum, and have adjustable shoulder bolt axles. Dual 6380 with 15mm belts are supported, as well as support for a variety of pneumatic wheels and bearing pulleys. The hanger shares the same cross section as caliber II, only square to make machining easier.
Specifications:
Material: CNC Machined 6061-T6
Overall Length (including axles): 325mm
Hanger Length: 220mm
Axle: 8mm x 70mm Alloy Steel Shoulder Bolt
Axle Length: 44mm-50mm
Weight: 290g
The pictures are just the sample piece, we are getting them anodized black for the final order. They will be available for purchase in 2-3 weeks There will be combo deals on motor mounts and hangers
