I specifically mentioned that it was the kit lol so it includes a lot more than the hanger
Motor mount kit lol…
Okay sure maybe that was wrong to assume he was providing those things but I did have other questions in there
A comp Randal baseplate in the rear is nice. A standard caliber 50 will do on the front.
Tagging this thread b/c I want at least one of those trucks for the front of a direct drive setup, along with some Caliber 2 baseplates.
Getting my full truck sampled right now.
Comes in adjustable 0, 15, 30, 40, 50, or fixed 30deg, 40deg, and 50deg. Press fit IMPERIAL kingpin. Riptide bushings and pivot cup. Same hanger. Basically everything you could want in an esk8 truck.
Also got kegel and flywheel bearing pulleys on the way. Comes in 36T and 40T. Modular system.
Motor pulleys in 13T, 15T, and 18T coming too. Keyway, steel, M5 set screws. Bulletproof
My motor mounts are getting a slight refresh. They will come with optional crossbars.
I should have all this in 2 weeks.
this is the greatest timeline
What kind of width will you be offering for the motor pulleys?
Congrats on your progress by the way, you are a cool dude, it was nice meeting you the other day Kevin
Some 22mm (belt, 23mm actual) HTD5M steel motor pulleys with 8mm bore would be awesome
with a 3mm keyway and M5 grub screws
I’d like 15T
All 15mm width from what I saw at his place
Getting excited for the full kit!
Is anyone else having trouble placing an order? I’m located in Texas but it says no shipping to that state?
No shipping to that state?
Not sure on that, but he is out of state right now, won’t be shipping anything until the 19th I think, but you should still be able to place an order I would think
Yeah it’s not working. I also tried to place an order to San Diego (where he’s located) but it’s not going through either. Not sure why I mean it’s only until next Monday so I can definitely wait.
Weird, hopefully you can figure it out when he is back
I might have to ditch my HeXL trucks and go for these instead. Currently running into a few issues with them. Anyone tried both?
Are you experiencing any issues with the trucks or bushings at all?
My bushings seem to be getting cut and @CiscoV noticed my front hangars were bending. I’ve only had maybe 40 miles on it so far.
Bruhhh your enclosure
People have experienced bending issues with the heXL
Unfortunately those screw counterbores create a weak point right were the largest bending moment is.
