Bruh, there is enough material on how to use VESC that it could fill up an entire university course
Seriously, the more you know, the more that you find out you donât actually knowâŚ
I just want a brief description of the duty current limit start issue.
I havenât made any special changes to settings on my boards for it, but donât know if I need to.
TLDR please?
ON AN ESK8, make sure âDuty Cycle Current Limit Startâ is 5% to 10% lower than âMaximum Duty Cycleâ (which is usually 95%).
On a Funwheel or balance vehicle, you want it set to 100%
On an ebike or whatever, it doesnât matter much
A good combo for esk8 is 90%, 95%
Perfect. Will check
What are the default values? And why are they not good?
Depends what software you use and what version. At this point, you should probably always set them.
Doesnât it have to do with faceplanting when going really fucking fastâŚlike when you dont expect it doing 40mph
The bad defaults were (are?) 95% âMax Duty cycleâ and 100% âDuty cycle current limit start.â
The reason thatâs bad is because when you make it to 95% duty cycle, the power/acceleration you are feeling doesnt slowly fade out, it just turns off like a light switch.
This sudden loss of power is often enough to throw you off an esk8 (especially if you are leaning into a hard acceleration, for example).
When you set âDuty cycle current limit startâ to 85%, then you start gradually losing power the after 85%, so by the time you make it to the 95% Max Duty cycle, you have gradually stopped accelerating and your board doesnt stop accelerating like a lightswitch.
This isnt really the thread for this though.
running higher voltage is better for the motors because you push less amps. i am running 18s on my flipsky bh 6374s with out any special settings. i ran motor detect, it set them for about 50 amps per i think, i left it that way. 400 miles later, they still run cool and spin nice. never thrown a fault. stormcore 100D. we just did a group buy of bh 6384s and i will be running 16s or 18s on mine, a few in our group are going high voltage as well
Fuck ya itâs going to be crazy busy for you hope you got help wish I lived in (The best city in Cali) SD still
Iâd volunteer
Whereâs the HYPEMAN @KaramQ I miss you Bro
What wheel adapter options will be available for the AT drives?
MBS
Trampa
Bergmeister
would it be possible to run 6" tires on the bergs on the AT? Berg adapters are available for the M1 too so whats the difference between getting M1 + berg and M1 AT + berg?
Difference is ratios and overall size.
The case on the regular drive is 72mm
The case on AT is 98mm
Regular drive keys into the spokes
AT drive uses the screws
Big speed
Big torque.
Only 27,360 minutes till the cncâd bounty arrives!
Iâll be ready
(Hopefully they arenât on that damn ship)
Theyâre on a different ship
You better bet Iâm not sleeping the day of delivery
Are the M1s the same configuration as the first batch? Any changes?
Also, do you have any raw sets coming?
Theyâre identical.
The wheel adapter hubs got a few minor tolerance changes. A few last batch had issues.
No raw sets
Evolve hub compatibility would be cool to have also.
