+1 stiffy
talk to me about the bearings. looks like the only consumable part
+1 stiffy
Yeah the case bearing would be the consumable. I could do some bearing life calculations but it would use lots of assumed data. I have spare bearings that size but installing them isnt easy unless you have a press, in which case its a minute job. They are not too snug.
what size is the bearing and is it readily available
edit: press fit? nice. if its not too tight maybe a bearing puller will work
Is there anyway to know if these kegel hollow wheels are compatable with the BNGD?
Readily available from me
it is a 6809-2RS. It is light-moderate tightness.
Someone send me one and I can answer that
If it is flywheel core then most likely.
When you get a chance can you take a pic from ground level
shawty get down good lord
Looks like you could reverse mount with those motors. And then do drop through
good god use a ruler. WTF is with the uneven mounting hole spacing?!?!
Not my doing, doesnât fuckin matter tho lmao. Imma stop showing off in Kevinâs thread
Thanks thatâs awesome
Man you just made my day after my davegx this is my next purchase you guys are making me poor.
How much are you risen??? looks like .75"
Yup but the 35° baseplate makes it so the front doesnât need any risers. Reverse mounting wonât work as itâll interfere with the hanger
you mean the split angles make the deck tilted and that is canceled out by the risers in the back?
I noticed that but not thattt much as to where I need ".5+ risers.
Yeah Iâm just bad at explaining lol
