Need a gear puller
Like a winshield wiper puller and hopefully you have alittle bit of space between pully and mount to fit it
Thanks for all the tips. I just ordered Loctite 768 Solvent. Hopefully it’s able to find it’s way through the 648 compound. Fingers crossed.
That sound legit. Let us know all about it. Is it acetone based?
Interesting, never considered a solvent for removal. Definitely let me know how it works. I may buy some and sell it for $1 if it’s effective
I read something about acetone
It’s 30-50$ for 1.75 Oz…
An Acetone soak is tempting to try. Been meaning to swap gears here myself
What about a gelled methylene chloride? Like a chlorinated brake cleaner would be better than acetone.
blowtorch intil smoking hot, make sure to rotate the fear so it’s evenly cooked, and flathead to lever it up slowly using the gd enclosure plate thingy mabob
This is the link to what I purchased.
The heat part is the last options, Im trying not to break my motor it’s attached to. I noticed when I applied a lighter (I know, not hot enough lol), my motor became rough when hand spun. Maybe I’ll try solder iron like the diagram.
Damn you iphone user! Change your coded or upload it to youtube so the majority can view it as well.
here you go bb
i found a better video
‘ayhaps
i’ven’t had any issues with torching the motor shaft real hard, what motors do you have?
SK8 6374 149kv
Marvelous
I got a gear puller but the space was too tight to fit and didn’t work. Resolved to torch and flat head too, works well with some patients.
M4 10mm had to get a new set as well.
I feel like a fucking idiot lol.
