No they’re like M4 but there is a special ones the ones that actually go on the star to hold a star to the pulley
the ones that mount the hub mount plate thing is m4 8mm countersunk
Thanks sexy toast show everybody a picture of your beautiful trampa see those gears in an action
it’s not letting me
One more question what spacers are you running between the star and rim
ooh! yes
it should be the thicker sort of spacer that cane with the drives. if you can’t find em, you might be abel to hit up @Boardnamics for some
Beautiful work
and everybody this is the way they should sound
Can’t see it but yeah that sounds similar to mine
Yeah for some reason the ones I got are for 10 mm axles but I have lots of 12 mm axles spacers
@ShutterShock after watching your video it didn’t look like a long spacer it looked kind of a short fatty one do you know the length I’m just trying to figure out I need to cut my bolts and I don’t want to cut them too short but then I don’t want them too long to break the star
It is a short fatty one because the gear itself takes up some of the axle space
If they are too short, you’re sol, if they’re too long then they scrape the casing, they won’t break the star
That’s weird that you got 10mm ones, Kevin must have mis bagged
As for the length… I mean, I am not super sure, it’s been a while since I touched anything on them. My guess is between 10 and 15mm
I just looked at it my video again and it’s definitely way shorter than that
Looks like 4mm
Maybe someone else can check, but that’s all I can give ya for the moment, not home rn.
i think it was 8-10 long?
Thank you
I watch the video and the spacing didn’t look much longer than 5 mm -10 mm from the stars to the rim I’ll figure it out I just don’t wanna be too long and have there be slop and that’s when things get broken broken
Yeah I mean I know how long a normal bearing spacer looks in my hand, and it’s definitely shorter than that.
I also have superstar wides so the 45 mm bolts that he sent do not work that’s why I’m asking all these questions a normal five star there about 5 to 10mm
This is why you stay in school kids basic math fucking with my head🤣
Tighten up the axle bolt and then make a measurement with a paperclip through the rim and into the star. Only way to get it right @Nacho
Does anyone know how to remove the pinion after Loctite 648?
sell it assembled lol maybe blowtorch and pliers
Get it to 450° or something near that and pull it
