I have some simple questions mostly about legacy hardware I want to get straight and there was not a organized place for these answers to be found.
This is a place to find out what size hardware a kit uses or BN hanger generation compatibility.
I have some of the oldest gen 1 I think hangers and the precision clamps don’t want to fit on, what mounts are they meant to use? is the the 2-part ones?
Grind a couple millimeters off your hanger where the plate hits the corner and it will fit with the precision clamps
Not even a couple… Maybe not even a whole milimeter… I just barely hit the corner of the Axle there with the dremel
My next question I just want to get recorded here is the spacer size used for the pulley
What’s included:
x2 44T Pulley
x2 Kegel Wheels
x2 Aluminum Spacer
x2 608-2RS Bearing
x2 6900-2RS Bearing
x2 M4x8mm Screw
Also the spacer size for the M1 drive…
How does one use T/Sunmate wheels on BN 270 trucks?
I don’t see anyone talking about doing it.
The new 10mm axles are probably the best option, provided you can get the old 10-8 ones out if you have those. Then you can use 16100-2rs bearings for the wheels. I’m running those with rockstar ii’s on 270’s with moon drives. Had to machine my own axles though.
Lol I was doing a search but nothing came up. Yup I am getting the solid 10mm shafts this time.
idk what you mean exactly
T rampa sells bearing conversion spacers that adapt the wheels to 22mm bearings, I tossed mine since they gave me nothing but headaches, its another element that adds play and they were either too tight or too loose. Superstar spokes in general are bad quality in general, wonky tolerances and some miss drilled holes on mine.
Same as trampa superstars is this what your asking for pulleys
Trampa has a better finish
The sunmates are worse in my opinion if you have both I feel like the trampas are made with a better aluminum but that’s just a feel thing haven’t done any homework on it
Sunmates
Right I got it now. So I just need to order the sunmate wheel set with the bearing hubs meant for 22mm od bearings then just use 6900-2RS.
oh but for actual all terrain riding 16100-2rs would be more ideal.
If you need to get new bearings, why use the spacer at all?
By spacer you mean replacing the bearing hub.
We are gonna derail this bitch soon.
So you do know what it is then… ![]()
That’s a better description ![]()
Are actually the same size spacer!!!
This one to be specific
The M1 drive one is actually Aluminum Spacers, 1/2" Outer Diameter, 5/16 Hole, 13/64" Long, AS50-16-13
