Wow will you be making any of those for the abec profiles?
Bi-weekly progress update
how we lookin on dem Baseplates
They have shipped to me
More progressā¦
Good day to you
carry on
Oh my lord. That is insane rosco
I was facing similar issue with my mov-e, but I want the narrowest wheel width possible so Iām extending the north/south wheelbase instead
Yeah I just tried it out because I canāt ride it otherwise and itās way too high with risers.
I have a set of g bomb brackets I bought for it but itās too long and Iām a hundred kilos so Iām afraid the extra leverage will break it (even after my repair job)
Might have to fab some short brackets like that. They look good
I donāt think it will stay like that. Prob use the 270 hangers on my Hummie.
(Or buy more
The two bolt holes at the very front/back of the deck will go through the deck/extension/truck.
Its made of 9mm 7075, iām sure its gonna be plenty strong enough.
Did you fabricate those brackets yourself? Iād like to know where they can be purchased if possible. Looks like it says āRadiumā engraved on top so searched on google but found nothing.
Always interesting seeing the many clever and creative things builders do to adapt or reach a certain goal.
The 270mm hangers look good too and Iād have thought that was the only way to cure wheelbite if I had the problem besides cutting the board which isnāt an option on the haya considering your cutting into the enclosure- But extending the wheelbase with gorgeously machined thick and strong brackets is an awesome idea from both a performance and aesthetic perspective
I did attempt to fabricate my own, but i couldnāt get the holes neat enough drilling by hand.
I had the brackets custom made by a local dude here in Melbourne. I still need to add the curve at the bottom of the new brackets by hand, at my request. He doesnāt visit the forum much, but shoot @Tony_Stark a message to see what he can do for you. Iāll let him know you are keen.
Alternatively, you could look at g-bomb brackets.
Haha yep the shiny brackets are my handy work (or the cnc mills, rather). My hand work is certainly not as good as Glyphs. You can see my other stuff on instagram @ RadiumEsk8. I donāt visit here much as @glyphiks mentioned
@Boardnamics anotha 2 week update progrezz checkā¦
Where we be brotha ?
Same place as before. The baseplates are being redone and will be shipped with a lot of other stuff later this week.
4sure⦠thx dood
No problem, thanks for the donut
U get
N
Wenn ur GD come outā¦
It will be everything you ever wanted
at a price that seems impossible
@Boardnamics pulleys and fixed axles installed in SR 177 TKPs and attached to tiller plates, tb110s.
All went together great. Need to make a 4mm thick 10mm spacer for the pulleys that sits up on the 10mm section of axle.
Still doing mockup. Will pull them and reinstall with loctite
What pulley ratio you running ? @bwahl602
