You could save space by putting the mr60s through the enclosure with or without a panel.
Be very careful with the balance wires(or any wire for that matter) placement so they don’t pinch off once the enclosure is mounted to the deck.
Yeah like @PedroMcJimenez said, I would route the balance wires as flat as possible with none crossing over each other, then isolating them from the ESC with the fishpaper I gave you.
Also make sure those charge port wires aren’t smashed between the ESC and BMS. I would use fishpaper there too.
Looks exciting, just started the fun part, putting all the electronics together
Tall barrel/ street barrel setup was a little stressed.
Street barrels vs Tall barrels (sourced from my meepo)
Removed the front short street cone and went with street barrels with washers all around.
Hope this helps with Top speed.
Jesus christ that bushing is flat
I’ve been messing with my set also trying to make them TKP but I’m a little heavy or I need to add better bushing and some risers
Kept tightening them trying to get more speed but the y look ready to pop!
I’ve tightened my trucks so much they barley feel like dkp anymore.
You’d rather have TKP over RKP or DKP?
looks great dude.
hope you enjoy it.
Thank you sir, I’m sure proud to have been able to realize this dream I’ve had for so long 🥲.
Im really enjoying the power and speed but now I need to figure out how to preserve/improve it’s manuverability.
trucks are a real personal thing.
for me I could not deal with DKP with power behind it.
they were fun. but with too much torque they were too squirly.
I dabbled a tiny bit with SKP with the Hexls, but it was not my bag.
On long boards I settled for RKP.
it is the most stable and predictable. but I can still carve enough.
no short radius turns…
my real favorite are the MBS Matrix II…
that is the bomb.
so just go ahead and plan a new build around that.
