Tyres are 165mm (6.5in)
@moon i used 220kv so same motor torque (4.71nm) assuming thats the kv, but in the chart the tires were 203.2mm, so you’d need 1.95:1 with those tires instead of 2.41:1…
165mm/203.2mm = 0.812
2.41 ratio * 0.812 = 1.95 ratio
@mackann when are you guys attempting the record?
lolz 27jasons
NSK
10char
Dont know for sure yet. It have been/is winter here atm. So have rided like 5 times since summer so need to get used to it again and to get confidence on the board first.
Did try to push it a little up to ~80km/h and it felt comfortable.
So will ride it for a few weeks and then make a try.
I have a 2 years old son 50% of the time by my own, a daily work and Bioboards work on evnings, nights and weekends, so I have very little time for anything atm😅
i did 90mph in my car last night & it felt dangerous… be careful
that said, this is for 18s (68.4v), 165mm tires, 220kv, 90mph capability w/ 4 motors:
^now you only need 74a motor current limit (instead of 109a), 70a battery current limit per motor (instead of 103a), 2.89:1 gear ratio (instead of 1.95:1), and 3.2nm motor torque (instead of 4.71)
Thanks, I dont plan to ride that fast. But will try for 65-70mph
for 70mph w/ 18s and 4 of the 220kv motors:
^now you only need 34a motor current limit per motor, 32a battery current limit per motor, 3.83:1 gear ratio, 1.46nm motor torque, 165mm tires, 69 wheel teeth and 18 motor teeth (the motor will be doing 232 revolutions every second)
That’s exactly what the 18s4p with 40t will give him 35a per motor
Excited to see where this goes
I’m still calling bs
how man rev/sec per tire does that equal??
@whaddys 60.5 tire revs per sec since the gear ratio would be 3.83 (it’s the 3rd # from the bottom in the upper chart)… the motor would be putting out it’s peak mechanical power with that motor current limit at 13925rpm (14th # from the bottom in the upper chart)
to get those rpms, you
look at the battery current limit per motor (32a)
divide 32a by the max duty .95 to get the motor current at peak mechanical power
I^2R = W to get the copper loss in watts at peak mechanical power (in this case 0.05ohm was chosen for R)
multiply the battery current limit by the battery voltage to get the electrical watts at peak mechanical power
subtract the copper loss watts from the electrical watts to get the peak mechanical power per motor
calculate the torque per motor amp KT = 60/(2 * pi * 220kv)
multiply the motor current at peak mechanical power by the KT to get the motor torque at peak mechanical power
divide the peak mechanical power in watts by the motor torque at peak mechanical power to get the motor angular velocity in radians per second at peak mechanical power
convert the radians per second at peak mechanical power to rpm
divide the motor rpm at peak mechanical power by the gear ratio to get the wheel rotations per minute, then divide by 60 seconds to get the wheel rotations per second
the trickiest part of the entire equation is starting with a slope, vehicle mass, frontal area, drag coefficient, fluid density of air, peak mechanical power and then converting that to max possible meters per second which is done at the 8th number from the bottom in the upper chart… in this case that’s slightly simpler since 0 slope was chosen.
i previously described how that’s done here:
Use this to protect your head.
@Trampa what’s the speed rating on Urban Treads?
We do not want our gear to be used at such speeds. We also do not want to advertise going that fast.
30mp/h is already plenty fast on a skateboard and well enough to hurt yourself badly. We enjoy riding with friends, riding on trails, pull off a jump, cruise up a nice hill, carve into the sunset etc.
It’s true. I read it in The Verge.
That point is true.
I was like, maybe I should build a Trampa. Trampa be like, nah, you should reconsider.
