Bigger than Boosted build log (42” vanguard, 18s4p, m1 drives)
On the stock wheels I was getting ~21 inputted at 101mm. I haven’t actually measured the wheels myself, but I think that’s what others were saying. But I didn’t ride much stop and go, mostly go. I think @ShutterShock was getting ~20, don’t know what his route is like.
On treated wheels I’m getting ~26, and so far it seems to be staying that way. I’m curious about the loss in efficiency compared to other wheels like say TB 110s. Because with the mad wheels you have the holes so those surfaces are going to be affected as well. Whereas with a TB 110 or more traditional wheel, the core is unaffected so probably retains a better roll.
For reference
I have more tests done this is just from my last review I did
Dadbod 105’s were 17.1 wh/mi but
WAY less confidence riding on those
I have not yet tried my treated abec 107s on an electric board.
Why?
I guess you’d need the abec adapters for these, but man super curious how they perform when you get to it.
I have abec and kegel adapters. And untreated abec 107s to test against.
They like to catch edges in the road (especially bike lane paint) and are much less forgiving than the mad 105’s, I’d choose mad over the dadbod any day but I’ve gotta finish my 100 miles
Catch edges like TB110s, better, worse?
Much worse than 110 lol
My night rides are cursed. My motor is freely slipping away from the wheel gear. Apparently I did not use enough locktight.
Oof that’s shitty, I usually use a decent amount of blue loctite. But I have heard of people using a drop of red on each bolt.
Tiny drop of 271 does the trick for me.
I used more than a drop of 243.
You can put Loctite 290 on it before — or after — it’s assembled, and it’s stronger than 243, but not so strong that you can’t take it apart if needed.
