I really hope they’re compatible with existing pulley bolt patterns like MBS or trampa
the hoyt plastic 5" are 3 bolt rims.
The rim is smaller than the mbs bolt pattern
FWIW, it really doesnt need to be. For those things, you want 48t pulleys, and the wheels are too small to work with AT geardrives. Kegel compatibility is all you need
set of 4 tire tube kit is ~$100 adj
so 150 for the rims pulleys, that includes… bearings?
$37 each? $42
Mbs bolts lie on an ~80mm diameter circle… Whatchu mean by this?
the bolts would be in the actual side wall of the rim
like, where there should be tube
Gotcha, you know the tire cutout/inner rim diam?
Something you want to tell us Justin???
True, forgot how small they actually are. Larger than 48T is asking for belt degradation
smaller than your rim
idk they posted a diagram here somewhere. i think the rim is about 100mm
Bitch my rim is toight
fair, if your rim was 100mm you’d be delivering a baby rn
shit thats expensive, I was hoping they could do $100 rims and $100 tyres and tubes
oh well, at least you know you’re getting good quality
It’s worth it. Quality is great. Grippiest tires I’ve tried.
Tubeless is a really nice touch. I really think tubeless is the future and will dominate the market over the next couple of years… I still can’t get enough of the Meepo tubeless tires.
Did you try the same meepo tire with a tube on another hub?
Maybe it’s just a nice tire and not the tubelessness…
I think it’s a combo of both things. The tire itself is well made, but the tubeless lets you run like 20psi or less to help keep the profile flat
are these really tubles?
