This video shows what the Catapult is bringing to the table very well.
The 1700 lumen light absolutely destroys the 3000 lumen lights in throw. The flood beam is quite nice too.
I stepped through the Olight R50 in the video before the Catapult. R50 is almost good enough. That hotspot the Catapult has will let you see potholes and other road hazards early enough for 25mph+.
The 18650 lights have good lumens at turn-on, but unless they have a crazy big head it’s all flood, and thermal step down kicks in really quick. If they’re putting out 2000+ lumens, runtime is kind of bad too. The 26650 lights have a bigger body for better head dissipation, and a bigger head for a bigger reflector, which improves throw. Bigger throw means you don’t need as many lumens, which improves time before thermal stepdown, and runtime.
The Catapult is doing some dark magic. That kind of throw used to only come with lights with heads twice as big. It runs fairly cool, has USB charging, is available in neutral white (cool white is more lumens, but neutral white improves depth perception in the dark – usually you can see more detail and distance with NW despite loss of lumens), and is amazingly cheap (throwers usually cost a TON). I’m almost talking myself into a spare, but there are always better lights coming along.
For fun, I think this Emisar D4s with 26650 is crazy. And so cheap! I’d grab a neutral white or high CRI LED version, with high cd (measure of throw). This light is floody by nature, the throwier versions are more useful and fun.
https://intl-outdoor.com/emisar-d4sv2.html
The Emisar D4 (1x18650) is also crazy fun for cheap. A real pocket rocket with a great UI. Fire hazard. I’d say the only downside is there’s no perfect pocket clip, which makes EDC inconvenient.
Emisar lights are also available in the US from http://www.mtnelectronics.com/index.php for a bit more $$. And skylumen.com has pimped out versions with upgraded/hotrodded components.
Oh I do believe the Emisars run open source firmware.
