can anyone link some good bearings in the uk
struggling to find the sealed zealous ones?
These fasteddy 608s will not quit
I pretty much exclusively ride them in the rain and they don’t care!
Bones 6 ball is good start, anything 6 ball is best
Could you link please?
also are zz or 2rs bearings better for our boards
They are US based only, basically just industrial OEM grade bearings with good cheap US shipping
got recommended skf bearings and they are reasonably cheap
your thoughts?
yep, if you haven’t tried them yet you should!
here are the 608
still questioning if these hold up to our abuse, wonder if you could run two of them in a longer bearing bore.
2rs always - Dampeing bro, as you probally know - Most shock Dampening - limits control to a degree from the user side.
However , Any Rubber from Wheels/to bearings/to Axle . Thats free dampening straight up (and yes it adds up and genuienly increases logeviety
Nothing beats skf, but i bet they are not “fast” bearings since they are industrial and use thiccc grease.
2rs does not dampen!? What are you on about its just a better dirt seal but creating a bit more drag.
For our purpose does fast matter since the power our motors output means lots of grease doesn’t make a huge difference
That issue is more for normal skaters no?
Yes, go skf
ZZ or 2rs?
2RS, even better just RS
Edit: you probably want your grease in your bearing, use 2RS
Why not ZZ (fully sealed with METAL)
Less dirt resistant, its more a protective impact shield, but leaves a big gap for water
Ah ok 2rs it is
Where is the best place to order from on eBay they are like 2$ each
I dont think they are €2 a piece, more like €6 i know a great dutch site, but not an english one. Though i saw someone posted about a good english site recently.
This is from the dutch site, skf only makes stainless too, which is gr8.
They are fucking expensive though
