If you want to just up your motor amps, or change one small setting without having to redo detection.
But playing âspin the hall sensors detectionâ wheel is so fun!
+1
Every Knipex tool i have used has been quality.
Anyone know how the fuck to get the flipsky vx4 remote to display my batteryâs status/ current charge level? Last week I had though it just didnât like the extra bat+ output on my focbox due to the current that pin can output. While adding in my loop key, I soldered the bat+ lead of the receiver to the positive terminal on one of the xt60 connectors and yet the remote still isnât displaying the batteryâs level at all. Everything else on the remote appears to be working on my desk.
Iâm using the UART mode if that matters at all
Edit: figured it out via this old thread reply
I also discovered that for whatever reason I cannot change the settings on the remote while connected to the vesc that is connected to the vesc tool. Weird.
Are the breaks always supposed to be loud when running belts?
On my desk the breaks worked nicely with no loud noises or skipping but when testing it they were loud and pretty jerky. Not sure if the issue is the belt length or if I just need to adjust the breaking curve in my VESC tool. Or if that is just normal for belt drives and they never brake the way that hub motors do.
Belts will switch poles more than hubs per rotation so itâs a lot âstifferâ even for the same settings, plus a lot more resistance so they always have baseline brake force
I suppose try a lower brake current, can you log a ride?
Hello everyone,
I am currently experiencing an issue with a Flipsky VX1 remote receiver that I recently purchased. I have found that the signal amplitude is significantly lower than other receivers I have tested, even when connected to a properly functioning ESC.
I have checked all connections and confirmed that the ESC is functioning properly, so I believe the issue is with the receiver itself. I have also tested the receiver with an oscilloscope and found that the signal amplitude is much lower than expected.
The vesc doesnât detect the signal in UART or PPM. but it works fine with other receivers.
I am reaching out to ask if anyone has any experience with this issue or has any suggestions for troubleshooting or resolving the problem. Any help or advice would be greatly appreciated.
Thank you in advance for your assistance.
Are these the same circuit? Is all youâve done is changed the receiver here? Is one of the signal wires broken? A bad wire/connection would be super suspect.
If none of that works, sounds like you should contact Flipsky and return the defective unit, thatâs smoking gun proof if they are on the same circuit and donât have any loose wires.
Flipsky does have a reputation of having low prices due to lack of adequate QC.
yes the circuit is the same only the receiver is different and the wires are all fine.
thx for the reply ![]()
I tried to contact them but to no avail⌠not only bad products but also horrible customer service ![]()
Also thatâs PWM and not PPM as VESC mislabels it
I Donât think I can log a ride since vesctool doesnât seem to want to work with the focbox Bluetooth module, and I donât think I can get the focbox/unity app to work with the firmware on the focbox.
I will check the brake currents once I get the board opened up in a bit, but I did grab a video of the noise to see if it is normal or not. Also worth noting that I left all the values as whatever VESCtool set as default, so if those are shit then that would be the issue
Sounds like your belts are skipping
Yeah definitely sounds like belts
There is no skipping when it is on the bench and I try braking. Is that normal?
Iâm guessing I should go up a belt size since Iâve got 315 on it now and I donât think I could easily put the 310s on it. I can also just go down to a 36 tooth pulley (38 on there now) which might fix it better than swapping to the 320 since that one felt a bit too loose I think? Been a few months since I fucked with the other belt sizes since I thought Iâd found the perfect size. (before actually road testing it )
Yes, because itâs unloaded.
Everything changes once you apply a load.
The way a skate works on the bench is typically not very indicative of how well it will perform once you stand on it. Everything is different.
Do you have any room on your motor mount slots to push the motors out further and add a bit more tension?
RIP my hands because Iâm pretty sure iâll need to swap the pulleys and theyâre bolt ons.
That isnât even a design feature on these mounts
I do have a hole and idlers if needed, but I think it will be easier to swap back to the original 36 tooth pulleys since I think that should fix the skipping problem without having the belts too loose.
The hole for the motor shaft is just a hole. No room to move it left and right at all. Only the bolts for the motor get the luxury of having a slot to adjust their positions.
You need shorter belts. Or an idler. Iâd personally try shorter belts. Try 5mm shorter.
Until then, turn down (up) your Motor Current Max Brake current a lot. (closer to zero)
I have shorter belts and they wonât fit on there easily. I can try again but Iâm pretty sure they would barely fit with the 36 tooth pulleys and just didnât fit with the 38 tooth ones on there now. I have 310mm, 315mm,320mm, and maybe some 325mm belts somewhere? (I donât think I bought any 325s but I might have)
