I think all my previous/current VESC boards I liked the brakes on, this is definitely the first time I’m experiencing such weak brakes. Like I mentioned in a previous post my current hub board has weak brakes (to be expected because of hubs), but it’s not even this bad.
The major differences here to past boards are the D100 VESC, higher kv, and higher voltage (20s). Using gears instead of belts but don’t think that has anything to do with this.
Currently using the Mad 105s
I’m going to try sensorless next to see if that does anything…
Y’all are right, tbf I haven’t taken it outside yet and tried it at higher speeds, maybe I’ve gotten to used to bigger motors. Will try it out and report back at some point.
He also reached out to me and asked me if I wanted to have my esc replaced over the strange batch 1 vesc remote issues. I declined as I’m having zero issues with my unit besides that, but the hoyt puck doesnt discriminate
Has anyone ever experienced a hoyt puck giving weird full reverse pulses when off throttle? Never had this happened before, not very inspiring when you have the board trying to pull out from under your feet when letting off throttle doing 50mph
Very, and it’s getting stronger somehow? It started with just a slight tap of the brakes while I was going through some corners but got to be like really strong, like scrubbing 10mph off my speed.
I don’t know for sure, Hoyt sent me this one to replace the last one that I had that also had a potentiometer issue, and ended up with a broken wrist and the remote in a river . Completely forgot that could be an issue, I assumed the new one they sent wouldn’t have that issue but I’ll check it out, Thanks, guys.
I opened up my board today following my confession here:
Fuse is fine. Charge port is fine. Voltage on mains is 49.1V. Voltage on charge line is 49.1V.
BMS is connectable via Bluetooth, everything looks good there (I think) with voltage at 49.4V.
My thoughts, what happens when you plug the charge line back in, do you get the same non zero reading off the external chargeport?
A connection to one of the p groups is loose and depending on how you jostle the pack it connects but other times it doesn’t so you get 0v reading. So I’d check those. Did you build the pack yourself?
