This is also ambiguous, because motor current and battery current are very different things.
Anyone know the steering angle on regular independent skateboard trucks?
What are cheap drive options for trampa cnc trucks. Where can i buy some motor mounts for belt drive that arent trampas? What other mounts besides the obvious fit these trucks?
Thanks
All those college folks on a budget that want to know how to build a skate for low amount of money, your answer is in here
Any help here, I must be doing something dumbā¦
Post screenshots of all your settings
Yeah weāre going to need some settings, although have you tried calibrating your remote? It almost sounds like thereās barely any travel registering on the negative side.
Yeah Iāll post as soon as I can. But thatās certainly an interesting thought, I did run the input wizard beforehand and it does move forwardā¦
Ok donāt know what changed today itās decided itāll work, including smart reverseā¦
#justvescthings
Ok braking is still super weak I thought if I got smart reverse working itād be better but no. When I reverse then go forward itās immediate and strong. But the other way around not so much
If using a pwm remote try -104% on youāre negative throttle.
Didnāt help feels the same ![]()
no clue, although I did notice when I went back from the D75 to the DV6 on the same board, same setup, same specs, same configs, same FW version, and the brakes on the DV6 seem far, far stronger than the D75.
I donāt want to assume so, but it seems like itās to do with the DXX series specifically, idk if anyone else has had a similar experience.
That part of smart reverse is annoying. It works great, but if you let off the reverse, then apply it again it will first stop before going backwards again, rather than keeping the current reverse speed. Once you get used to it, it works OK
As for the weak brakes, the settings look pretty decent. You could try -80 on the motors, even for 6355s. What was the default detection results? Is this set on both sides?
Is the duty cycle limit intentionally lowered to limit top speed?
Do you have a screenshot of the mapping tab? Maybe the settings from the input wizard were not saved?
Yes, I made sure to apply settings for both sides. I think detection was around the 60ish mark. Good to know Iāll try -80 as well for these motors. I think I did try something ridiculous like 100, but let me try again.
Yup.
Iāll send a screenshot when I get the chance, but Iāve run the wizard multiple times now making sure to apply the settings.
In a last ditch effort I may reflash the 5.3 firmware with the default one in the VESC tool. Just gotta remember to keep phase filters offā¦
Why do you need reverse on a esk8?
Sometimes front wheel drive is better?
You are stuck in a very narrow space and need to back out?
Holding your position while stopped on a downhill.
But I prefer āHyst Reverseā mode much better.
If you ever do road riding, reverse is incredibly useful.
Back out of an intersection, 3-point turn, correct for missed turns, back up a bit at a crossing light to let people pass⦠The list goes on.
