Good thing that’s 14AWG hehe
@magharees the FET side is silicone potted, all of it is conformal coated and additional silicone on top of components on the topside of the PCB
Wut mr30 for
charge port hehe
Huh. Are you using the third for anything special?
lol no, it’s just small and convenient
30A per pin iirc
So 90a per!? wow.
I avoided them cause I thought it was 30a total. Went out of the way and designed some myself with bullet connects for 100a… each… so 300 amps now that I think about it!
also keep in mind it’s 3 phase connection so it’s not the same current flowing through each pin at the same time like a battery
Yeah I’m still confused
about how to configure my motor amps based on my battery, current, wattage of motor, etc
This should cover everything
Wait so If I am running 110a motor amps and 60a battery it will work and not burn up? (I wont pull over 90a cause im light)
in theory yes, but what motor do you have that does 110A?
@Scepterr thanks for the link!
Mr 100 pound speed demon deeif over here.
‘Youngest esk8 rider’ how old r you then? At that weight your in what… 6th grade?
(Not tryin to be creeps, it’s just impressive and my interest is peaked)
well in theory if you have a motor that size(110A capable) you will need more batt amps for it to move you or HV
Damn…
ur boi just turned 16 but u hold up to your title.
How the hell u finance this?
Why would you use a magnetic charge port over a regular charge port?
You got a habit of riding off while chargin?
