I think I’m right but let’s here from the man himself lol.
@VodkaMan two 1s lipo in parallel or two 1s lipo in series?
Not really sure why you’d want 2S for a remote but ya, curious to hear from OG
This also played into my assumption lol.
wat is happening
The lipos are In parallel, there shouldn’t be a problem with voltage dif.
I’m going to post an improved version of the shell with a groove for the pinky in a bit😛
So what is it you’re using in the diagram that’s labeled BMS? this?
Sorry for my ignorance I’ve no experience in this specific realm of battery knowledge
Yes sirrrr, I should’ve written charge board in hindsight
You good, just glad someone is doing and sharing this dank shit. Thanks again gonna see if i can’t figure out how to put this thing tgether this week. Figuring out how to position the spring and throttle knob looks to be the most annoying part
Twice as many zooms
@VodkaMan I’m attempting this and having some roadblocks!
The power bottom is glowing on regardless of depressed or not
The AliExpress battery indicator isn’t glowing/responding
I think i have this hooked up properly, overlooked all my connections they look good.
You have constant power to the led.
Actually i got the original power light to respond now (turn on and off) in response to the latching one now in the on/off positions, but the latching one still stays lit up all the time. Battery indicator also still not powering
How would you fix that? Sorry I’m dumb, just following the diagram =\
yeah they definetly sent the wrong one. you need the ones with components on the back side of the pcb, the front should only have a button and leds.
lemme see how did you connect the power button.
Ahhh the power button must be where I went wrong. Slightly different placement of your + leads on this last diagram vs your first one
Looks like i shorted the wrong positive side
sorry bro that was my bad, shouda checked it twice before i posted
