I love the mini remote but it didn’t have a batwing case, and now it does!
SKINNY WING MINI
FATWING MINI:
note (FATWING):
the order of components going into the case from left to right is
charge board
battery
battery
mini remote PCB
flip the switch on the mini remote to on and break the arm of the switch.
use hot glue to glue in the charge board and the indicator PCB, everything else won’t move an mm because of the tolerance.
parts list:
103035 lipo (1 for the skinny wing, 2 for the fatwing)
Battery indicator (SMD version) X1
TP4056 charge board X1
Power Switch (12mm 5-6V latching version) X1
enjoy
J0ker
October 9, 2021, 3:36am
#2
I think it was @bboybowzer but I may be wrong.
Following as well
Edit: I was wrong
Linny
October 9, 2021, 4:14am
#3
It’s done by @AaronTech2
Also yes! Do it! I have mini remotes too, and i love the bat wing puck case.
Extremely crude test fit in order😂
Dope dude, all i use are minis so I’m super into this
How does 2200mah battery sound?
This is a killer development.
Love it! Is that a little 2S BMS sandwiched between those batteries/cells??
It’s a 1s lipo charge board, i had 2 1100mah lipos laying around and they fit so why not😂
Linny
October 10, 2021, 2:02pm
#12
Wait, a power button?! explain!
So the original power switch felt like crap and I had a push button laying around, so I put the original switch to on position and broke it and connected the switch to the power wires.
Now I have a separate issue, there’s just not enough space for the power indicator unless I thicken the entire thing by 3-4mm. Also I still haven’t found a good placement for the USBC port, everything is wayy too tightly packed
Powers on but still have to sort out the indicator and the USB port placement.
first working Prototype!
Mini remote internals
Don’t need to reverse the potentiometer wires
2200mah battery
USB-C charge port
Battery level indicator
Clicky on off switch
J0ker
October 11, 2021, 4:16am
#16
You keeping them files secret or you going to share lol? Love the progress already.
Haven’t gotten response from the OG maker of batwing and I don’t want to post without his permission lol, don’t want any grievances.
But yeah I intend to make it public.
Baxter
October 11, 2021, 11:09am
#18
Any plans to make a more conventional puck version?
It’s going to be a Big puck then, because the PCB barely fits in this one as is😂
for the daredevils that want to try this mod here are the files.
note:
charge board
battery
battery
mini remote pcb
use hot glue to glue in the charge board and the indicator pcb, everything else won’t move an mm because of the tolerance.
parts list:
103035 lipo X2
I’ll post the wiring diagram once i have time to draw it up.
enjoy
