Classic: starts on sale. Rucksack for the too many batteries we all have now.
https://batteryhookup.com/products/new-battery-hookup-lifep04-32650-3-2v-5000mah-cells
Should I get some for the lolz even tho I shouldn’t…
50A!!!
would this be a good Kweld battery?
Do you plan on welding several thousand welds per charge? Haha. Seems like a lot of capacity for welding
lol I’m already using 16Ah (2x 3S1P spim08hp)
oh yeah just checked and so far I’m only down to 12.4V from messing around a bit.
Could do a pretty big pack in one charge I think.
https://batteryhookup.com/products/bmw-oem-3s-12v-85ah-869wh-battery-module
wait no this one actually
nice is that a liion pack? or an LTO battery?
12V @ 3S so li-ion. It says 12.6V max
all the other BMW batts were li-ion I think
Oh I’m getting this for my malectrics…thats dope!
yeah I keep thinking about how good of a battery it is for like camping! (A time where you wouldn’t need to be spot welding probably)
Totally a good deal you can run all your 12V stuff easy
They seem pretty used and lower capacity.
Don’t forget dirty!
This is a real “just throw a little wood and some trucks on there and call it a day” battery modules.
The packs weigh 20 lbs. and dimensions are 31" x 7" x 3"
Then just awd with some cheap escs and dickyho motors
Even at minimum capacity, that’s still a 350wh pack with stupid levels of discharge capability. $10 for a bms=$70 for a super robust battery to thrash for another 5000 cycles
yeah… sadly I have so much else to waste my money on…
They look like a scary cheap and good time
that 31" just registered to me. You could almost just mount the trucks to the battery pack
maybe just layer it with some fiberglass or carbon or pot the whole thing in resin and ready to go. love to see that. i just bought a gallon of resin for potting cells. hard pu. was told epoxy is not the best to use and too rigid. pu is cheaper anyway
@hummieee
Make the box you include with the new hummie decks fit these at a stretch pls
it is designed for 26mm cells max correct? or something else?
would be dope to see a potted lifepo4 pack in a esk8
