nah, use 10S2P 40T or P42A. Most of my meepo customers report a range of 26-30km at 35-40kph (converted from freedom units).
But be warned you’re likely to have to modify the internal structure of the case, on the sides specifically. Half the packs I send out squeeze into place the other half the customers cut some of the enclosure with a razor blade or dremel to fit the pack. I don’t know for sure if this is meepo related or customer related, but I tell everyone before they buy of the possibility.
Just wanted to let everybody know that I can fully recommend Acido and his battery packs. He was building a battery for me last year and he was always very responsive and helpful. Shipping within EU was no problem and the battery was perfect.
A couple of weeks ago I had dead p group and he could help me find the problem quickly and fixed it.
Hi,
I am looking at the same thing as my french friend above a 10s 3P and would like to have a ball park of pricing.
I guess it depends of the cells and configuration and since it’s for a mountainboard (VESC6.6, 9/35 ratio, 200mm tires and a 95kg pilot) i need a good balance between discharge and autonomy as to avoid voltage sag or being stranded 5 kms from home (i plan for 10-15km rides at 30 km/h max on flat pavement).
Thanks
