First up, sorry to be one of these people that makes these threads, but I promise I wouldn’t have done it if I didn’t have to…
So I have this BMS, this charger and a 10S3P battery pack that I have had for around ~5months and in the past 2weeks the charging has been playing up, sometimes it would work other times not. Then it just stopped working altogether, sooo I order a new BMS (same kind as above) and got it today. And guess what? It still doesn’t work. I measured the cell voltages and all are within 0.1v of each other:
Oh yes, I have checked the port and the 42v from the charger is coming through all good I have a feeling its the charger but there is 42v coming out of it (from the plug) so i’m not sure…anyone taken apart one of these chargers before? don’t feel like dying today
If the BMS was the issue, it would tell. If the charger worked without it. But since its wired in parallell with everything since its charge only, it shouldn’t matter since the BMS only has balance function and dsn’t pass the current. (unless you wired it weird somehow?)
The Charger itself should start if input voltage(battery) is less then 42V. So if theres a BMS or not, the charger dsn’t rly know/care
after removing the BMS from the battery and hooking up the charger accordingly, it works…! which means that the BMS is the one to blame. Will double check everything before filing for a refund to make sure everything is hooked up correctly. To be honest this doesn’t surprise me as this is only a cheap $15 BMS.
Hi guys! I have a 10S4P who don’t want to charge over 60% and discharge very quickly.
I bought a new BMS (10S 60A charge + discharge, Autobalancing) still not received. My battery give me this voltage :
3,46: 6,94 : 10,42 : 13,89 : 17,6 : 22,xx : 27,xx : 31,xx : 36,xx : 41,xx.
Spoiler, It’s a Raptor 2.1.
In my opinion, the battery is fine but the BMS is just fucked up.
What’s your’s?
Yeah sorry, my volmeter have only 20V or 500V as options, so after 17.6 I had to set it at 500V and I don’t have decimals. I’m just happy there no “0” as Delta.
Instead of measuring from ground to each balance pin, measure from balance pin to the next balance pin. Then you can get 3 significant digits precision for each P-group. However, do notaccidentally short them out!!!
