Randy
June 4, 2020, 12:05am
#1
12S4P Q30,…2 Ollin board 4.12 (80A,60v)Vesc’s, (2) 6374 maytech motors ,no BMS.
Am i getting Full pontential out of these 2 motors ?
…I know the 4P should be able to provide 80 Amp.
…I know Motor Amps vs Battery Amps vs Cycle work in a very complicated manner.
Depends on your settings, but probably not with vesc 4xxx hardware.
I say otherwise IF they are properly cooled.
*keeping the 4.12 limits in mind.
If not, the 4.12 is the weakest link due to the produced heat resulting in throttling.
The vescs are the weak point.
Most tend to avoid running 12S on 4.12 vescs as well
Randy
June 4, 2020, 12:43pm
#5
These ollin vesc are good for 80A… and they’re taking only half the load each since I have 2…
Anubis
June 4, 2020, 12:59pm
#6
If you’re running 80A @ 12S on a 4.12 based VESC you’re in for a super shitty time
Randy
June 4, 2020, 1:22pm
#8
The board runs awesome I just wonder if the battery is the bottleneck
Jujo
June 4, 2020, 1:24pm
#9
You asked what is the weakest link. If you want to ignore everyone else answer and advice then don’t ask a question like that.
Now if you’re asking for maximum potential, then that’s a completely different question
Should be fine on Ollins 4.12, not sure about the 80A part though, Ollins 4.12’s were ditect-fet 4.12’s with a beefy heatsink
Was often as highly regarded as focboxes
Anubis
June 4, 2020, 1:44pm
#11
You need to turn the battery max regen wayyyy down. probably to -8 amps
LMAO, does this board even turn? channel truck at 20 degrees? I hope you are blasting the song “move bitch, get out the way” while you are riding.
Randy
June 4, 2020, 1:54pm
#14
there is a wedge that you cant see.it’s30°… not as Twitchy as a trampa at high speed
Randy
June 4, 2020, 2:01pm
#16
Diy
added an extra coat of carbon fibre on the bottom
Randy
June 4, 2020, 2:07pm
#17
I didn’t say I was running them at 80A …I said they’re good for 80A and 60V…and I have 2 of them on 1 battery so I think I’m fine
Randy
June 4, 2020, 2:10pm
#18
ollin vesc are good for 13S
Anubis
June 4, 2020, 2:15pm
#19
Because battery max regen isnt braking strength, its the returned current that recharges your battery. Are you going to be charging your battery at 80 amps?
Randy:
Diy deck
Say whaaaaa?
Do you have a deck-building thread? I would love to how you pressed that deck with them compound curves and all
Randy
June 4, 2020, 2:37pm
#21
Sorry, I didn’t press that, I bought it like that , and shapped it to my preference
