Hi folks I’m got a board coming to me with this pack in it:
I wanted to check with them that it would be OK to use my 8A charger on it and they said best not to go over 3A with this pack or 5A at the most.
Looking at the datasheet for the Samsung 40T is does show a max charging rate of 6A:
…but I think they are confused because in a 12s3p configuration the max charging current should be 6A*3=18A which is way over the puny 8A my charger can put out.
Yeah I can’t really do that since they already said if I want to keep my warranty I can’t go over 5A.
So I can’t be like OK I won’t BUT IF I DID what’s the specs on that BMS?
the thing is, even some 8A rated bms, will heat up quite a bit even just charging at around 6A. if propulsionboard is really using an 8A bms, then 5A is a reasonable current to ba safe
I already have the 8A charger that’s all. I can set it to any volts and amps I like.
I would probably charge at 1A almost all the time anyway because if I’m not using the board again that day it doesn’t matter how fast it charges so might as well put as little strain on the batteries as possible.
