Battery Help Need :) | Overkill Commuter | 5kW |12S4P
Like these then (in case another poor european soul is looking for it): 1 meter nickel welding strip- 25mm*0.20mm - Battery solder strip - Accupackaccessoires - Battery accessories | NKON
Almost sounds too good to be true, but reasonable. Can’t believe I haven’t given these as much consideration as I should have. Going to try and switch to them instead.
But then I’d be back to the same dillemma again. Instead of having 60A to worry about I potentially got 140A to deal with (is it advisable to build to a limit set in the VESC like 100A or build to the max?). @A13XR3 would .2x25mm still be enough? What makes you say it is enough for 60A, is it from experience or something similar to this chart?
.2mm thick nickel seems to be hard enough weld, I can’t imagine needing to triple it to be within optimal range. Would that imply silicone wire is my only option when going over 60A?
I will proceed, taking into account all your guy’s feedback and post a final more formal battery plan before I start welding.
