So i messed up on my first diy build. I bought a flexible battery enclosure and had a battery built into it. However, i didnt consider the curve on the width of the MBS deck and now i got a small gap on the edges between my deck and enclosure. Its roughly a 1/2 inch gap. I’m pretty sure some thick insulation could fill the gaps. Any suggestions for material?
There’s some good options in this thread.
dont get foam. it will squish and you will be back to where you started. get some kind of rubber.
Neoprene rubber. This is what I use to clear my battery w smart bms on top.
https://www.amazon.com/dp/B07JNV4B14/ref=cm_sw_r_other_apap_pwx6hxiOQ3Up6
Don’t squish is that hard…?
I’m using pipe insulation foam and it’s working good ! But obviously you’ll need a lot thicker foam than rubber because of compression
Cool! Appreciate all the suggestions! I’ll buy that rubber neoprene!
Measure twice, buy once. Make sure it’s tall enough.
I ordered the bigger roll. Figured i could cut stuff off if it’s to big
