Yes, expected price is per set, includes pulleys and belts.
and the motor mount?
Set includes:
- motor mount
- truck adapters, available for rkp, tkp, tb218, and caliber
- idlers
- wheel pulleys, choice of 34 to 44t (one tooth increment)
- motor pulleys, choice of 14, 15, 16, 18, or 20t
- wheel adapters for abec or kegel pattern, bolt on
- xbars
- covers
- mounting hardware
That is amazing value!
Sign me up!
How do they sound compared to gear drives?
With cover on, sounds quieter than an open belt drive system and gear drives.
How is the groundclearance?
Would 85mm be to low?
What size do u recommend?
Oh shit. Perfect for us lame asses that love belts. I want them too. In fact. I’d need 4 of them
Would you be offering adaptor for Tb cnc trucks? @Janux-esk8
Ground clearance for 107mm wheels is ~16mm or 5/8".
Running 85mm wheels give you ~5mm clearance.
I don’t have TB cnc trucks available to design an adapter. If you don’t mind sending me your truck, an adapter could be made.
Any chance these will work with a 10-12 tooth motor gear?
Any size motor pulleys up to 24t can be used with my drive. I don’t carry any 10-12t pulleys.
the projected 200 is that for a single assembly or for a set of 2.
Projected price is dual motor setup.
E: I’m s l o w
The splined connection between plate and hanger bracket is pretty slick. Is that the pressfit on the end of the hanger?
Impossible to slip “Radial Lock 360”, https://www.youtube.com/watch?v=rb9bIXVOcTI
Each click is 8 degree. Theoretical 45 possible positions.
Possible wheel pulleys: 34 to 44t, increment by 1t
Choice of motor pulleys: 14, 15, 16, 18, and 20t
Total of 55 ratios are possible
Any matrix ll love coming?
Is on my to-do list. Would need to modify motor plates and covers to accommodate larger pulleys. Recommendation on range of pulley sizes?
I’m just getting into the mtb stuff.
Someone like @glyphiks @Venom121212 @DerelictRobot @ducktaperules or @Andy87 would know better than I.
