I think there is enough market around that size. I understand the cost of a new mould but someone should make it
Thanks very much for the help
The Cal 7 wheels are excellent for the price. For you first build if your on a budget they are ideal. Iāve had a set of Cal 7 90mm wheels and they have been very good. Buy them if they are within your budget.
But always be mindful of the āfree bearingsā offered with your wheels. Itās always good to have spare bearings stashed in a box somewhere for emergency, for prototyping, or for the kids, but bad bearings will affect your ride as much as bad wheels.
When youāre pushing your board, you easily notice when your bearings get tired, dusty, seized and it makes pushing a pain in the ass. When youāre riding a powered board, and even more when itās a comfortably powered one, you may not notice an extra drag, or ignore a squeak, until the bearing overheats and potentially melts your core, and your wheel is fāed, and you need to buy another 4 pack of themā¦
centrax by abec11. and I sell hub motors that go with them.
Haha yeah same! They are sitting in my cabinet of random parts. Little bit hard but other than that they worked great
All bearings are not created equal, the better ones have seals to keep the dirt out, not just covers, there is a difference. Having sealed bearings even if they are cheap is better than unsealed ones.
What brand of reliable and best performing bearings would you recommend? Please dont say ābonesāā¦
Zealous and BONES
Argh!
Bronson speed co.
Oh and reds
Bones Reds LoLz
No, for real. All jokes aside. You can spend a lot more but Iām not sure the ROI is there. I just use Reds now, back to the basics.
If you didnāt have a motor on there then bearings would matter a lot more.
why not use a sealed bearing?
Have you tried zealous ceramics?
I use zealous ceramics with PTFE dry lube and two good sized glops of white lithium grease in mine and they still roll as smooth as the day I opened them up a year ago. I only paid $27, I think you will find they are a huge step up from bones reds. I have kept reds going for years, but only with shit tons more maintenance.
Whatās that? is there a brand specific?
No its just a type of bearing, sealed vs shielded
Looks like so many recommends for Zealous - should be it, I suppose. I keep hearing from some āreviewsā that they are slow, and not for speed. Very confusing⦠Thanks anyhow.
unless your bearing is actually fucked the percentage increase in rolling resistance is so insignificant compared to other factors, that there is like no point not running a sealed bearing
Donāt know if Iām allowed to do this⦠but Iāll just copy and paste from another post from another forum :
Ok hereās the deal with bearings and Eskate.
Bearings in general⦠Donāt matter that much through all disciplines of skating.
I mean, they matter. But theyāre all 95% the same. And the cheap Chinese vbx bearings you can buy by the hundreds arenāt really going to be distinguishable from bones swiss without taking them off and reading the shields.
Most of the differences are invented to create marketing hype.
One such difference is free spin. Free spin may matter in a teeny tiny minority of incidences but one instance where it 100% does not matter is when you have a motor attached to your board doing the work for you.
Lots of skate specific bearings come with oil and thats to give them lower rolling resistance, because weāve been become accustomed to think that is what feels better.
Eskate you donāt want that.
It is SO easy to heap on tons of miles on an eskate that a normal skater will never see. So basically the only purchase consideration for eskate builders, apart from cost, should be durability and longevity.
As far a ceramic is concerned, that difference is a matter of performance.
Performance that is completely non-applicable when youāve got a motor.
And as far as Iām aware there is no lifetime or durability benefits to ceramic.
What youāre probably going to want to focus on instead is the bearing Lube.
Lube is what keeps the bearing working, free of rust, free of wear, and its the thing that will keep your bearing rolling for many miles.
Oil gives lower rolling resistance, at the cost of not being as good at protecting the bearings, being more susceptible to washout, and needing to be replaced semi-frequently.
What you want is aluminum complex greases, mostly for their incredibly high water resistance.
Water damages the bearings directly by rust, but it can also wash out your lube causing them to go bad through wear. - CHAINMAILLEKID
I tested bearings on inline skates, where they matter way more than eskate.
Bones Swiss Super 6 vs. store brand china bearings - abso-fucking-lutely no difference.
No difference in longevity either. Putting a drop of bearing oil in them will make more difference than anything else.
Donāt bother with anything crazy expensive.
