Are the flipsky the best budget remote?
hello
was going to order one of these? are they any good or is there a better budget one out there i have a 12s battery
thank you
Best budget remote is a Mini…they are $20 on eBay and AliExpress, and it’s got amazing reliability. Only catch is it used AA batteries
have you got a link please?
Yes they are good remotes!
Btw you can get them a bit cheaper. Here is a link to the seller I brought mine from-
Worth everybody’s while to just save a little more and get the Hoyt midnight
ITs definitely the best ~$50 remote. Three speed modes and a battery level indicator, a good feel in the hand, lovely throttle wheel, UART or PWM operation, i like them a lot.
that link does not work :{
It’s working for me. Try the link again.
no still doesnt work, whats it called maby i can search for it?
Yup buy once or cry a bunch, don’t settle for a crappy mini or a disconnecting vx1
is it called a hot midnight?
You pay for quality, look no further.
as in signal drops due to radio noise? they behave better in my area than any other remote ever has, and i used to get a lot of signal drops.
It should work now!
Yup I’ve seen several disconnects in a busy city, not worth it
Also look at the Kaly and LaCroix group pages, it’s a fairly common issue
I think quality control may be the issue with vx1. Some are rock solid. Others, not so much
Also haven’t you used a Hoyt?
can you use the vx1 on a 12s battery?.
the st midnight is a bit tooo expensive for me but looks good
Yeah the vx1 battery indication is compatible with 8-12s if I’m not mistaken
8/10/12
