Maytech motors can come with made to order shafts, size, KV, magic.
If you are stuck for a key and don’t want to wait then the shank of a 3mm drill bit serves the purpose. Cut to size and bobs your mothers brother.
1 sec of angle grinder will convert that motor into a D shaft motor, next problem…
It’s just I have to hunt around local suppliers in Australia for a key that will fit. Will prob have to order in though because hardware stores in aus have nothing
D shaped pulleys are the future IMO.
Now they just need to use the D shape to secure the bell end and you’ll have solved the second biggest issue with esk8 motors.
The only problem is having to say “D shaped shaft”
Is that really a problem?
I just have to embrace D shaped shafts now
I think we all just need to embrace a little bit of D in our life.
It’ll change ya I swear!
er.
3mm drill bit.
Some of done need them and prefer to us prefer to use retaining compounds.
D shafts can actually be terrible if you mess then up.
If you never want your pulley to be permanently stuck on the motor be very careful, or don’t use D shafts.
Unnecessary cost imo when other cheaper solutions are available. They do have advantages when they work correctly though.
When I hit the brakes, I want a piece of metal stopping me and not some glue.
Plus once you’ve tried to remove one of those pulleys that’s been attached with only adhesive, you may change your mind
Try it you may be surprised Brian. My gear drives are just 680. Its amazing. To get it off just requires a little heat. One of those mini blow torches you would use for a creme brulee.
I did try it.
Keyways FTW. D-shaped are okay but I prefer keyways. Adhesive alone is not okay for me.
You fucked it up then brother.
I absolutely did not fuck it up. It’s just a bad idea, imho
Keyways are much easier to work on and there’s actual metal holding you.
I also prefer that the pulleys I’m grabbing are not 300 F (149 C). I could never get one loose until right around the 300 F mark then it starts to loosen up
I absolutely agree with that statement but it does work. I am a bit like you though and like there to be a non rotational element in my pulley system.
Keyways always end up clicking if you don’t use grubscrews on the motor pulley. And I always lose the tiny fucking grubs.
A dshaped pulley with no grubs held in place by correct spacers and circlips is revolutionary. At least it was for me, nor more fucking around with a 3mm bar of metal.
Definitely needs way better tolerances to work well tho I’ll give ya that!
I use the tiniest dab of cyanoacrylate (superglue) on the key to stop rattles and Loctite 290 on the grub screws and some of that gets on the shaft too but I don’t put it there on purpose.
Best way I personally have found that’s still servicable.
Oh, and M5 grub screws (not M4) for the win.
