So thereās realistically 2 big general versions that set the standard and thatās it? (Ignoring 75/300 and specific designs)
Also, assuming one uses 4.x hardware and doesnāt run into any bottleneck type of limitations, would there be any reason to upgrade to 6.x?
Can i use the temperature pin in the hall sensor to measure the battery temperature? My motors donāt have temperature sensors
What sensor part number do i need for that?
Does the other end connect to 3.3/5v or gnd?
I donāt see why you couldnāt⦠here is the post I followed from @mishrasubhransu he added a thermistor on his hanger, I opened the motor can and used a smaller 10k thermistor to my stator⦠Iāve since disconnected them due to all the faulty temp. sensor throttlingā¦
good luck
Mine would connect, but if I didnāt calibrate it with the up down thing somtiemes itād be insanely mis calibrated and fly off or slam breaks with the slightest movement.
realizing 10s6p 20700s might actually fit better than 12s5p
Yes, version 4.5, 4.6, 4.7, 4.8, 4.9, 4.10, 4.11, 4.12, 4.20 are all two-shunt designs
Versions 6.0+ are all three-shunt designs
I donāt seem to find in that thread and donāt really want to read 1300 comments; between which pins does the thermistor go? Temp (white) + ?
Thanks for confirming my theory by the way
just clicky the link I provided.
it takes you to exactly the correct post
Nevermind. It was right there⦠sorry
If you were looking to run a motor in FOC mode with battery amps maxing at ~45A, would you go for a new Maytech v6 vesc (MTSVESC) or an OG Focbox?
I thought this one was hard
that one looks really interesting.
can someone please suggest which side (ridged edge or smooth curved one) faces the center of the board? i donāt know what is the proper way to mount these wheels- google searching says āgraphics out, inside side towards the truckā, but that isnāt helpful⦠help plz
Flat, ground side faces in.
Even if I noticed that the ridged/flat-side faced in pulls the wheel pulley further back into the wheel? Would having the flat edge face out instead be much worse? Like with the flat edge towards the truck, the wheel sticks out past the wheel pulley rim.
hmmm. a pic would help, but the pulleys I have on those exact wheels sit perfectly flush on those flats.
How big is the pulley? How many teeth?
It is a 36 teeth torque boards one- I canāt get a clear picture but the pulleys rim is just a millimeter behind the wheel. And I donāt think this was a problem before I tried correcting the orientation, so rn Iāll deal with the 6 bolts to flip it around and test it
LiFePO4 is far more resilient to things than li-ion or lipo
I run Cal7s with smooth face curved edge OUT⦠many miles no issues⦠the core is centered in the wheel, so to me It really doesnāt matter⦠if the hub was offset⦠then Iād say run offset outā¦
