Yeah I saw that when I entered the numbers on the calculator.
I’d still be chilling tho right ? Don’t want to overwork any of my parts. I’m not gonna be going 52mph anytime soon so I don’t think it would make a huge difference right @BluPenguin
If the calc says 52mph loaded top speed then your motor pulley is too big or your wheel pulley is too small
Use the pulley that gives you a top speed a little bit higher than you want to go and you’re good.
that is the best way
Loaded is 47mph with 18t and 36t … we chilling ?
No, you want loaded top speed to be around 31mph usually
depending on a lot of things
Those are Li-Ion cells from Volkswagen E-Up
4C constant discharge (100Amp) is easy for them
How in the world do I achieve a loaded speed of 31 lol🤣 ever with 16/36 I’m still at 42 loaded on a 12s4p30q @BluPenguin
Btw I’m running 6374 190kv TB motors
And no I’m not joking, I’m really wondering
15/42 or 15/40
I want to add wheels to boosted board which one will fit?
That’s still like 35 is that close enough
Thanks!
I bought 100g of 1mm rosin core solder from AliExpress
Wheels with a kegel-style core, like Orangatang Kegel, @torqueboards TB100, Ahmyo Akasha, Orangatang Caguama, Boa Constrictor, Ollin Popoca
Yes, definitely
i have a makerx v4 on 3.62 firmware i tried upgrading to fw 5/5.1 but when i did it does the whole firmware upload and then i reconnect to the vesc tool and it just comes up as 3.62 again
what can i do to solve this i have tried both sides on can and also tried 1 side at a time still doesnt work
thanks
Put a bootloader on it
how can i flash one to both sides?
i only have a vesc 6 spare
