Seems like your ordinary Chinese AIO ESC you can buy for 30⏠on eBay etc
it looks slightly different than the typical liying escâs
Does anyone know where to get adapter cables for Hoverboard chargers? Would need a Hoverboard plug to Xt60 and one to DC Jack 5,5 2,1
I fear that I will reduce the battery life of my 10S3P Samsung 30Q battery significantly by charging it with 5A
Any numbers?
Setting up my drive system and one of the motors has a lot of hand resistance. Any suggestions? @b264
Something shorted?
Yah are you saying with disconnected phase wires you feel resistance (no load/belt or anything) if so sounds like phase wires shorted.
Such an incredibly bad name one letter away from âlyingâ. Should start a clone shop called âweecopyâ
i think i misunderstood. so you actually have your board on while upgrading as well?
I donât have a uSplit so i canât help with that. I just went with what the steps said. How does one connect the usplit to usb? via the vesc directly?
edit : i see, it has a dedicated usb port.
The question is if the usplit gets enough power from just the usb or if it needs power from the vesc and usb is just for data transfer.
If it needs power from the vesc unplug the usb and restart your board.
If only usb, just usb. But going from the manual iâd say it needs vesc power
@pookybear
I saw your comment on the other thread butâŚuhm⌠i donât know what power cycling means lol
cheers @xsynatic
Power cycling is the act of turning a piece of equipment off and then on again
Power cycle is turning off your board and on
haha well that was a noob question
can you answer this?
uSplit needs to be powered thru vesc, and usb for comm.
I had tried updating mine just using usb, never got it to work. It has to be plugged in to both.
Edit:
Hw 1.2 does NOT have any button you push to get into flash mode. When usb is plugged, it automatically goes I to recovery mode. In contrast, hw1.1 needs it pushed and held down before turning esc on.
Well know the âremove canbus while powered on and youâll kill the vescâ story.
But is it save to leave the cable plugged while nothing is connected on the other end and then turning it on?
Is there a complete âhow toâ on building batteries or do I have to read through the 6000+ posts in the battery builders club thread ?
I didnât have the time yet.
@Mainsedora - No, no, I wasnât knocking you. I appreciated your post and I know itâs a work i progress.
This hobby is awful, I keep on falling into these rabbit holes, the latest being battery building. Everyone here learned from somewhere, just wondering if there was a guide I can reference.
Need help again One motor is spinning the wrong direction on the Unity. It says DRV fault when I reverse one of the motor directions.
Time to swap the phase wires instead of using the UI
