I am looking at using @eboosted 's 12s BMS but it states that he only builds them for charge and not for discharge because it isnt safe.
Mentions power loss from braking on a full battery which i get but how is that discharge? Thought that was charging. And because you cant overcharge so it goes to heat at that point. So does this mean that it doesnât support regen braking?
I canât imagine it would go above 20A batt without some active cooling. An FPV flying in the air at 100km/hr will be able to be used at slightly higher power
I think you miss something. Bms is wired for charge only, indeed.
From the charge plug, through bms, to battery. Charging.
For the esc, the wire comes directly from the battery, with no stops except for the antispark/loopkey. The esc draws power safely like this, and when you brake, sends that extra energy back into the battery. If the path to battery is interrupted when you brake, the esc explodes. And a bms tends to cut the power in the nastiest situations
Ok so what does he mean that he doesnât build them for discharge then? do some do that? and what does discharge actually mean I guess.
not knowing much I imagine it safely takes it down to a certain level for storage.
