4.12 flipskys donāt have heatsink. 27a is usually considered max on these so go for 25a. and -8 x 2 is perfectly fine.
I think you are severely underestimating the power thats about to hit your 65kg ass. lol
YES. This is a common problem when people focus on specs or ābigā numbers.
For acceleration, breaking or both :)?
By the way, thatās why I asked you. You have experience. No way I could have known that the 50A continous 240A burst Fsesc 4.12 is only really capable of 27A due to heat issues. Since my battery can only provide 50A safely as it seems, 25A on each VESC should be just fine!
I am going to run Sensored FOC I think
What is your gearing and wheel size?
Shots fired
in my experience, 4.12ās donāt handle foc elegantly
iāve seen some with 4.12ās say they run foc just fine, iāve seen some say they blew up their controller
for me it just doesnāt work off the bench. bldc sounds freaking amazing though
15T Motor / 36T Wheel - the standard 2.4 ratio
97mm Abec clones
Mutant may indeed have a better setup. I just like laddering up as a discovery/learning process.
Well, Bill said these are starting values to slowly work up from
4.12 handle FOC at 10s just fine @ reasonable settings. I used some for 1k+ miles
Really? Mike Beard said the opposite in a tutorial xD
Seems like everything could blow up your Flipsky VESC.
Only thing Iām a bit afraid of is my 50° Trucks⦠Should have gone lower degree I suppose. Makes so much fun to ride unmotorized⦠But I donāt know how bad the speed wobbles are ^^
Thats why i only started using foc back in november because i always feared killing my 4.12ās. I daredā¦and never looked back. I donāt even know anymore how bldc sounds⦠
edit : i use it on 10s and 12s. Fat guy on mtb. Hills and offroading.
you learn fast ![]()
Well we are speaking about flipsky after allā¦
Flipsky is like McDonaldās. You know itās not healthy and not really tasty either, but you see yourself buying it again and again. XD
honestly at 50 euros, they are hard to beat if you have reasonable expectations.
@Niklas the N00b thread is the right place to be starting these ādiscoveryā type questions. If i may ask when you land on your final ESC configuration would you mind posting this thread for others to reference?
i thought we had one for ESC settings as well but cannot immediately find it. if it doesnt exist iāll create one later today
so how much did you end up spending in the end?
iām happy to stand corrected! glad to hear that foc works so well for many on 4.12
i often blame myself when things donāt work as they should, but in the case of 4.12ās iām inclined to blame my hardware
Hi guys. Im just about to spunk about Ā£200 on Flipskyās 6384ās. Can I grab some last opinions beforehand and anyone aware of current shipping times?
Cheers.
