That is strange for sure⦠You said you tried 2 remotes but did you switch out the receiver? I feel like either something is wrong with your setup or somethingās defective⦠Bioboards uses the vx1 on their high power stuff and if all the vx1s did that, youād think a lot of people would be faceplantingā¦
One of my receivers came DOA, only have 1. Setup works fine with Nyko kamas, mini remotes and I have the same problem UART/PPM with both VX1s, Ill film a video really quickly tonight to show how bad it is. I wish it worked, i love the form factor but its just awful to ride.
I wonder if your other receiver also has issues. Interestingly, no problems on throttle? May be a bad suggestion but what if you reversed throttle and brake? Does it still do the same or does the problem reverse tooā¦
0 problems on throttle, really smooth acceleration. Havent tried reversing throttle but will try that tonight.
ok removed these and replaced
, installed new remote mini with new receiver, relocated receiver to the front of my board, also turned off thermal throttling. Went for a ride and no micro braking/cutouts@Athrx where in the uk are you?
Just out of interest and wondering if your anywhere near me
Awesome result! So you couldnāt narrow it down to just one thing, or decided the holistic approach is fastest to a solution?
Are those audio cable connectors? The tips are rather short?
Iāll have to check my amazon ordersā¦I donāt think they are. that would be craaaaazy if they are. Now that you mention itā¦the tip does seem sorta short.
those were the only things i did not replace/double check.
My vx1 is smooth with breaking (ver. 3.** Firmware)
MakerX CHesc
London, you?
Same in London
Postcode?
What chargers do you guys use for grading of individual li-on cells before building the pack?
I found XTAR VC8 close to my needs but it does grading(charge-discharge) only on first 4 channels not all 8ā¦
@Athrx Iām in nw11
You anywhere near me?
I used to top balance all my cells it my 4 littokala 500s
But with new cells I find a multimedia is enough to make sure there are no duds. after building the P groups I Ballance capacity test 6 groups at a time with my imax b6 plus.
are those vacuum formed?
I have one it looks like 3mm kynex sheet I think they oven bake them like fish fingers.
those enclosures
they look like they are
I canāt find 500s on amazon.
What about lii500?
