I need a matching motor mount kit for this, so:
Pulley
Belt
Motor mount plate
Trucks
Wheels
(bearings are not really necessary, got them already)
As an alternative to this:
Maybe I can get the parts cheaper seperately and save on shipping.
I would buy them from dickyho on ebay. I would love to hear your guys recommendations.
What about this as cheapest enclose possible - spray it black and you got yourself an enclosureā¦
Its only 4,45cm or 1 3/4 inches in height so optimal size i guess. Roughly 16cm wide and 50cm long. VESC and stuff in the small chamber and Battery in the big one.
One question: For my little flexy board, is a 28143 (cm) battery safe? 3 cm is REALLY thin⦠i would secure the battery to the ground of the box, i fear that when the deck flexes, my battery or the enclosure gets crushedā¦
Maybe make a small support frame around the battery? Like a cage or so?
People do the same with flower pots⦠i really canāt recommend it. the plastic around the screws will fail real quick since the vibrations are so strong. you donāt wan the guts falling out mid-ride
That would make an awful crash with many broken parts. you could always ask @BigBen what small enclosures he has as they are amazing quality and a very reasonable price. it depends what size battery you are wanting.
I can choose if i want a more rectangle or cubic one⦠I think id rather have 5cm for the battery in order to keep sfae from breaking the battery in half
the plastic material will break. We always use either abs, fibreglass, or sometimes carbon fibre.
The other option is topmounted like @rusins did with one of his builds (canāt remember where).
he used a very big pencil case velcro-ed down to the board
I am in need of two simple vesc, with priority being cheap and fast delivery in the Eu in these difficult times. Any reason not to buy these? Wanted to try the x makers small ones, but the China thingā¦
Here is my board. It does flex pretty much, but do you think it will cause problems?
If so, do you happen to know really budget options with similar look/shape?
