9Ah is fine. Half of my boards are 5.5Ah
maybe 20 miles or so, depends on your weight and alot of things
Separate but not because of the simultaneous thing. Which you can do if separate.
Itās mainly because BMS capable of proper discharge current are more expensive. Normally only charge is needed for BMS. Discharge is handled more or less on the vesc side.
Please stop offering stuff for sale in non-sale threads. Iāve seen you do this a few times now.
So loopkeys⦠mounting them. I get the whole idea of them but for a square mount how do you go about cutting a square hole in a Big Ben enclosure?
A dremel is probably the best bet. Just start small and work up to the required shape to avoid blowout/cracking.
The USB port on my slave ESC has shit itself. If I set new motor current settings on the Master, do they get copied to the slave?
Worked fine last night, went for a test ride this morning and now the computer is saying that the device has malfunctioned
Iām not very familiar with can stuff but Iām pretty sure vesc tool has a can forwarding option to modify the slave settings⦠If a more experienced vescāer could chime in thatād be ideal.
Yep i figured it out with can forwarding
Playing around on the 3D servisas Cacalacor I noticed that the lower you set your n for batteries in series, the higher your torque. For some reason I thought that the trade off between P and S counts on your battery was top speed and range, but is it top speed and torque? a 12s4p battery will have shittier torque than a 13s4p (assuming the same cells)?
Torque is motor and motor currents. Has nothing to do with P and S count, but total cell count. More cells, more total watts, more power can be sent to motors. S count increases voltage which increases max motor RPMs for a given system.
dude I was having a mental melt down. Like my whole physical nature was deteriorating at the seams. Thank you for saving me
@BluPenguin one thing Iām still confused about thought is how cell discharge affects torque. Does it? Like will a HG6 20650 rated at 30A punch more torque in a 12s4p config than 30qs? Because I thought that rating was just the amount of A it can theoretically discharge before overheating
Well, torque is directly based on motor current. Motor current x RPM is power. On the battery side, S count voltage * amps = power. If you increase the total power capable of the battery, that means you can feed more power to the motors to higher RPMs. Basically, the less power your battery is capable of, the sooner your motor starts dropping off torque as speed picks upā¦
ahhh, so with a cell rated at 30A, would you set the current limits on the BMS or the VESC to push the battery harder than you would for a 15A cell?
You donāt have to but thatās the goal. The higher discharge batteries are so people can pull more power out of the same size pack.
Why is this so much cheaper?
[51,53⬠33% OFF]Flipsky Mini FSESC4.20 50A ESC
Than this:
And isnāt this one of these mini remotes you guys keep recommending as the ultimate budget solution :)?
Thatās the one. Itās fugly but seriously capable.
Because one is made by flipsky, and one is not. Flipsky makes (and sells) things cheaper than other places.
