I wouldnātā¦
Just take it off with a soldering iron.
Dremels are not exactly the most precise tools.
Pliers and your soldering iron will do the job
Is their a huge difference between a 170kv and 190kv 6374 motor
One spins faster than the other?
It doesnāt sound like much, but it was enough for me to have to swap motor pulleys to get back some launch when I went 170 to 190.
Is it possible to run different sized(and different kv) motors and gear drives on a single mtb or do i need everything the same ?
To further explain, i want to upgrade to 4wd, i currently have the trampa motors(6378, 160kv) and gear drive(1:5,8) and vesc6, i want to add etoxx maxi(1:6,25) and aps 6384, 170kv and vesc6
And would i run the 4 vescs via can or split the remote signal, or two receivers ?
I mean, thereās nothing stopping you technically, afaikā¦ But youāll get a torque difference between the two kvās that could mess with your ride.
That should be okay as the new drivetrain will be on the front side, only thing im worried about is if tires will be at different speeds, or trying to
Vesc is torque based not speed based, so different KV is okay. But keep in mind back voltage. If the 190 accelerates the board past the top speed of 170, braking could send over voltage back to the ESC, since the 170 is going faster than max RPM. But if youāre running 10s its probably fine
Why is my motor reading such a high resistance? My motor wires are soldered to the vesc, no bullet connectors if that makes a difference.
Running 12s, so dont max out the max speed on the lower kv
Welcome, is the soldering job good ?, pictures perhaps ?
@BigBen have you ever considered making a 4WD Hummie enclosure? Basically, make it have a wire outlet channel on both ends. I presume the demand probably isnāt large enough and Iāll have to buy two and DIY it down the middle. I quite enjoy your enclosure for that deck.
may all your dream come true my friend
Ha, finished it a couple of days ago.
Hahaha. Niiiicee. Iāve definitely been thinking about this for ~8 months now
Iāll still have to CF it because I like taking my deck off curbsā¦ But thatās going to be a perfect long range cruiser setup
[quote=āBindings_McGee, post:12493, topic:126ā]
[/quote]Me too. Finally got the time.
So I just resoldered one sketchy links and got the reading down to 137, is this a good level?
Itās a judgement call - If both lipo packs are the same age and from the same manufacturer, with the same cells inside (just a different number of them), then youāre totally fine. But if any of those arenāt the case, then the actual capacity and characteristics of the different cells might not match, and that could result in a Very Bad Thing.
For example, I absolutely wouldnāt do a Zippy 15Ah 3s in series with a Turnigy 15Ah 5s.
